System requirements for Devolutions Hub Business
To use Devolutions Gateway, your system must meet the following requirements.
Hardware requirements
Minimal implementation
(1 to 5 concurrent sessions)
Small implementation
(5 to 15 concurrent sessions)
Medium implementation
(15 to 75 concurrent sessions)
Large implementation
(More than 75 concurrent sessions)
2 vCPUs
4 GB RAM
4 vCPUs
8 GB RAM
8 vCPUs
16 GB RAM
Deploy multiple Devolutions Gateway instances.
A Gigabit Ethernet controller is recommended for optimal performance.
Software requirements
  • Windows 10 (version 20H2, 21H1, and 21H2), or Windows 11 (version 21H2)
  • Windows Server 2016, 2019, 2022, or 2025 with .NET Framework 4.8
  • Ubuntu Linux 18.04
  • Red Hat Enterprise Linux (RHEL) 8
  • Rocky Linux 8
  • PowerShell 7 (required only for using the Devolutions Gateway PowerShell module on Linux)
Certificate requirements
Devolutions Gateway supports TLS 1.2 and TLS 1.3 as well as the following cipher suites:
  • AES_256_GCM_SHA384
  • AES_128_GCM_SHA256
  • CHACHA20_POLY1305_SHA256
  • ECDHE_ECDSA_AES_256_GCM_SHA384
  • ECDHE_ECDSA_AES_128_GCM_SHA256
  • ECDHE_ECDSA_CHACHA20_POLY1305_SHA256
  • ECDHE_RSA_AES_256_GCM_SHA384
  • ECDHE_RSA_AES_128_GCM_SHA256
  • ECDHE_RSA_CHACHA20_POLY1305_SHA256
