Maintenance Tool database connection is invalid
This error message occurs when trying to make changes in the Devolutions Server Console while being unable to access the encryption.config file:
Maintenance Tool database connection is invalidSolution
Open command prompt and type
whoamI. It might simply be that you are connected as a user without permission to access the encryption file.Make sure you have the Read permission on the
encryption.configfile located inC:\inetpub\wwwroot\dvls\App_Data.Once the correct permission has been granted, restart the Devolutions Server Console.
Last updated
Was this helpful?
