> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/server/knowledge-base/troubleshooting-articles/login-failed-for-userx-with-sql.md).
# Login failed for UserX with SQL
Fixes a SQL login failed error in Devolutions Server caused by an account locked after repeated failed login attempts, with steps to unlock it.
If the `(0x80131904): Login failed for user 'UserX'` error code appears when attempting to connect to the workspace, it is possible that the account has been locked after multiple login attempts. It depends on the configured password policy enforcement.
### Unlocking the SQL Database
The following SQL Query will confirm if the user has been locked:
`SELECT LOGINPROPERTY('UserX','islocked')`
The user can be manually unlocked by going to the user ***Properties*** – ***Status*** and unchecking ***Lock SQL user***. Then changing the password and finally executing the changes.
#### Alternative
Alternatively, the following query can be used:
`ALTER LOGIN [SQLID] WITH PASSWORD = '****' UNLOCK`
To learn more, read the Microsoft [SQL documentation](https://learn.microsoft.com/en-us/sql/sql-server/?view=sql-server-ver16).
GET https://docs.devolutions.net/server/knowledge-base/troubleshooting-articles/login-failed-for-userx-with-sql.md?ask=<question>&goal=<user_goal>
