Connection issues when switching network
Scenario 1
When switching your computer from a wired network to wifi, Remote Desktop Manager and Devolutions Password Manager disconnect from Devolutions Server and you have to reconnect.
Scenario 2
If you have multiple different public IP addresses, Remote Desktop Manager and Devolutions Password Manager are not able to connect to Devolutions Server.
Solution
To prevent this behaviour, go to the Devolutions Server web interface and, under Administration – Server Settings – Security, disable Force token public IP validation.
PreviousCannot rename the table because it is published for replication
NextCryptographicException - Bad Data
Last updated
Was this helpful?
