> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/server/knowledge-base/how-to-articles/prevent-sql-timeouts.md).
# Prevent SQL timeouts
Managing a lot of entries in one single operation or having a high number of connected users could lead to SQL Timeout error messages with Devolutions Server. The following modification on the database advanced parameters could help to prevent getting SQL Timeouts.
1. The first one to consider is the ***Connection maximum pool size*** Increasing that parameter to 1000 instead of the default 100 will help to level up the number of possible database connections.
2. The second parameter is the ***Connection timeout*** that can be increased to 30 seconds. This will make the system wait for 30 seconds before raising an exception.
3. The last one is the ***Connection retry count*** as it will repeat each ***Connection timeout*** delay before generating an error. By setting it to 5, the Devolutions Server instance will wait 150 seconds before raising an SQL Timeout.
   <figure><img src="https://cdnweb.devolutions.net/docs/DVLSCONSOLE4000_2024_1.png" alt=""><figcaption></figcaption></figure>
For more information about these parameters, please see [Database – Advanced Settings](https://docs.devolutions.net/server/devolutions-server-console/devolutions-server-settings/database/advanced-settings/).
GET https://docs.devolutions.net/server/knowledge-base/how-to-articles/prevent-sql-timeouts.md?ask=<question>&goal=<endgoal>
