> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/server/knowledge-base/how-to-articles/configure-a-web-based-active-directory-dashboard-entry.md).
# Configure a web-based Active Directory dashboard entry
The Active Directory dashboard can be launched directly from the Devolutions Server web interface.
### Requirements
* Windows 10 or 11.
* Windows Server 2016 and later.
* [Devolutions Gateway](https://docs.devolutions.net/gateway/getting-started/server/server-configuration/) version 2023.1 or later.
* The [***View*** ***password permission***](https://docs.devolutions.net/rdm/user-groups-based-access-control/permissions/) is required to launch the session via Devolutions Server's web interface.
### Entry configuration
Properly configure an Active Directory dashboard by following the steps below. First [create an Active Directory dashboard entry](https://docs.devolutions.net/server/web-interface/vault/entries/create-entries-manually/) if not already done.
1. In the ***Properties*** of the entry, go to the ***VPN/tunnel/gateway*** section.
2. Under ***Connect***, select ***Always connect***.
3. Select ***Devolutions Gateway*** as the ***VPN type***.
4. Click ***Update*** to save.
   ![](https://cdnweb.devolutions.net/docs/DVLS6010_2026_1.png)
### Open the dashboard in a browser
Once all the conditions are met, click ***Open in browser*** to launch the connection on the web.
![](https://cdnweb.devolutions.net/docs/DVLS6011_2026_1.png)
### User interface
![](https://cdnweb.devolutions.net/docs/DVLS2040_2024_3.png)
#### Dashboard settings
<table><thead><tr><th width="186">Settings</th><th>Description</th></tr></thead><tbody><tr><td><strong>New user</strong></td><td>Create a new user in Active Directory.</td></tr><tr><td><strong>New group</strong></td><td>Create a new group in Active Directory.</td></tr><tr><td><strong>Find BitLocker</strong></td><td>Retrieve the recovery password for a BitLocker-encrypted key.</td></tr><tr><td><strong>Enter search filter</strong></td><td>Locate any object within the domain, such as users, groups, or computers.</td></tr></tbody></table>
#### User and group settings
<table><thead><tr><th width="216">Settings</th><th>Description</th></tr></thead><tbody><tr><td><strong>Enable</strong></td><td>Reactivate an object, making it active.</td></tr><tr><td><strong>Disable</strong></td><td>Disable an object without deleting it.</td></tr><tr><td><strong>Unlock</strong></td><td>Release a user account that has been locked.</td></tr><tr><td><strong>Reset password</strong></td><td>Assign a new password to a user account.</td></tr><tr><td><strong>Delete</strong></td><td>Permanently delete an object from Active Directory.</td></tr><tr><td><strong>Properties</strong></td><td>View or modify the attributes and settings of an object.</td></tr></tbody></table>
GET https://docs.devolutions.net/server/knowledge-base/how-to-articles/configure-a-web-based-active-directory-dashboard-entry.md?ask=<question>&goal=<endgoal>
