Configure a web-based Active Directory dashboard entry
The Active Directory dashboard can be launched directly from the Devolutions Server web interface.
Requirements
Entry configuration
Properly configure an Active Directory dashboard by following the steps below. First create an Active Directory dashboard entry if not already done.
  1. In the Properties of the entry, go to the VPN/tunnel/gateway section.
  2. Under Connect, select Always connect.
  3. Select Devolutions Gateway as the VPN type.
  4. Click Update to save.
Open the dashboard in a browser
Once all the conditions are met, click Open in browser to launch the connection on the web.
User interface
Dashboard settings
Settings
Description
New user
Create a new user in Active Directory.
New group
Create a new group in Active Directory.
Find BitLocker
Retrieve the recovery password for a BitLocker-encrypted key.
Enter search filter
Locate any object within the domain, such as users, groups, or computers.
User and group settings
Settings
Description
Enable
Reactivate an object, making it active.
Disable
Disable an object without deleting it.
Unlock
Release a user account that has been locked.
Reset password
Assign a new password to a user account.
Delete
Permanently delete an object from Active Directory.
Properties
View or modify the attributes and settings of an object.
Last updated
Was this helpful?
