Add a web entry
A Web entry stores login credentials for a website, allowing users to save and retrieve web-based credentials directly from the Devolutions Server web interface or from Remote Desktop Manager connected to a Devolutions Server workspace.
Add a web entry from the Devolutions Server web interface
Select the vault or user vault, and the folder in which you want to create the entry.
Select the Add button.
Select Website from the entry type list, then select Continue.
Configure the entry with the required information.
Select Add to save the entry.
Add a web entry from Remote Desktop Manager
Open Remote Desktop Manager and connect to your Devolutions Server workspace.
Select the vault and folder in which you want to create the entry.
Right-click the vault or folder, then select Add new entry.
Select Save to add the entry to the Devolutions Server workspace.
Last updated
Was this helpful?
