Skip to content
User connection mismatch
Connection failed due to mismatch of users during the authentication process.
Solution
You will get the user mismatch message when you configure a user but connect with a different user. The Username specified in the workspace configuration and the user selected via the form must match.
Last updated
Was this helpful?
