> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/ssh-shell-supported-ecdsa-keys.md).
# SSH Shell supported ECDSA keys
Fix the Unknown ecdsa curve group error in Remote Desktop Manager SSH Shell by confirming your key uses a supported ECDSA curve.
`Unknown ecdsa curve group` error appears when connecting to SSH servers.
### Solution
Confirm the public/private key is supported by Remote Desktop Manager
RDM Windows and Mac support:
* ecdsa-nistp256
* ecdsa-nistp384
* ecdsa-nistp521
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/ssh-shell-supported-ecdsa-keys.md?ask=<question>&goal=<user_goal>
