> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/ssh-shell-entry-failed-to-connect.md).
# SSH Shell entry failed to connect
Shell entry failed to connect with interactive authentication.
An unknown SSH error was encountered.
No authentication method available
Errors appear when connecting with an SSH Shell in Remote Desktop Manager 2019.
### Cause
***Interactive authentication*** in terminal is set to ***True*** under ***Advanced*** tab.
Under ***File – Settings – Types – Terminal***, interactive authentication in terminal is also configurable.
#### Solution
Change the value to ***False*** if Interactive authentication in terminal is not required.
#### Alternative Solution
{% hint style="danger" %}
Adding lines in SSH server may break the authentication process. Never perform this without a backup.
If interactive authentication is required to confirm that the SSH server includes lines:
`KbdInteractiveAuthentication yes ChallengeResponseAuthentication yes UseLogin no UsePam yes`
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/ssh-shell-entry-failed-to-connect.md?ask=<question>&goal=<endgoal>
