> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/ssh-application-keypad-not-working.md).
# SSH application keypad not working
Application keypad not working correctly.
When trying to use the keypad in SSH, it does not send the correct characters when you type.
### Solution
In the ***Terminal*** tab, set the ***Disable application keypad mode*** to ***True*** so that the option works globally on all your sessions.
<figure><img src="https://cdnweb.devolutions.net/docs/docs_en_kb_KB4098.png" alt=""><figcaption></figcaption></figure>
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/ssh-application-keypad-not-working.md?ask=<question>&goal=<endgoal>
