Skip to content
SqlException - column, parameter, or variable
SqlException - Column, parameter, or variable #16: Cannot find data type datetime2.
Solution
This error occurs when you are using an SQL Server 2005, which is not supported. You need SQL Server 2012 or later.
Last updated
Was this helpful?
