SQL Server installation fails
Attempting to install SQL Server with Devolutions Server Console on a machine that does not already have SQL Server installed causes the process to fail. This issue occurs in version 2025.1 of the Devolutions Server Console.
Solution
The issue can be bypassed by performing a manual installation of SQL Server Express.
Last updated
Was this helpful?
