SQL Azure workspaces and Devolutions Password Manager browser extension connectivity issues
The Windows 11 update KB5066835 disrupted development workflows by causing the localhost interface to fail. Affected users reported HTTP/2 errors, failed connections, and issues in tools like Visual Studio.
This issue mainly affects SQL Azure workspaces in Remote Desktop Manager and Devolutions Password Manager browser extension.
Unable to connect to the database.
Failed to authenticate the user in Active Directory (Authentication=ActiveDirectoryInteractive).
Error code 0xhttp_listener_error
An HttpListenerException occurred while listening on http://localhost:56553/ for the system browser to complete the login. Possible cause and mitigation: the app is unable to listen on the specified URI, run 'netsh http add iplisten 127.0.0.1' from the Admin command prompt.Solution 1
Install the KB5007651 patch.
Solution 2
Uninstall KB5066835 patch.
Restart the computer.
Uninstall KB5065789 patch.
Last updated
Was this helpful?
