SQL Azure one or more errors occurred
After following the steps in Configure Entra ID App Registration, you receive the error message below:
System.AggregateException: One or more errors occurred. ---> System.AggregateException: One or more errors occurred
Solution 1
Validate that the type of Redirect URI is set to Mobile and desktop application. Changing the Redirect URI value after creating the manifest will require that you delete the wrong redirect and add the correct one in the Authentication section.
Solution 2
If you still get this error, please send us your Entra ID app manifest at service@devolutions.net so that we can validate your configuration.
Last updated
Was this helpful?
