RPC troubleshooting
The RPC server is unavailable (exception from HRESULT: 0X800706BA)
This error may occur in the normal operation of Remote Desktop Manager The root causes are network connectivity or stopped Windows services.
Solution
Ensure the host is properly identified (Name or IP address) and it is indeed running and accepting network traffic.
Ensure the host firewall allows inbound traffic for Windows Management Instrumentation.
Ensure the following services are started and are set to automatic startup type.
TCP/IP NetBIOS Helper
Remote Procedure Call (RPC)
PreviousRestore the RDP file association with mstsc.exe
NextRun Remote Desktop Manager under application verifier
Last updated
Was this helpful?
