Remote Desktop Manager crashes in versions 2024.1 to 2024.3
Users may experience unexpected crashes in Remote Desktop Manager when running versions 2024.1 through 2024.3.
Before proceeding with advanced troubleshooting, ensure that all required dependencies are properly installed and that common corrective actions have been completed.
Step 1: Verify required dependencies
Confirm that the following components are installed and up to date:
Step 2: Update Remote Desktop Manager
Make sure you are running the latest available version of Remote Desktop Manager. Newer builds may include stability improvements and crash fixes not present in earlier releases.
Step 3: Reset local Remote Desktop Manager data
  1. Close Remote Desktop Manager.
  2. Navigate to %localappdata%\\Devolutions.
  3. Rename the Remote Desktop Manager folder to RemoteDesktopManager.old.
  4. Relaunch Remote Desktop Manager.
  5. Reconnect to your workspace.
Step 4: Adjust Remote Desktop Manager settings
  • In File – Settings, set Wait progress mode to Status bar.
  • Verify that the Wait-Loading Progress Bar is enabled for all web sessions.
  • Switch all RDP sessions to FreeRDP for testing purposes.
Step 5: Report the issue
If Remote Desktop Manager continues to crash:
  • Provide details about the exact behavior of the crash.
  • Check Windows Event Viewer for relevant error logs.
If the issue persists, contact service@devolutions.net and include detailed logs.
Last updated
Was this helpful?
