Skip to content
Proxy authentication required error
When opening Remote Desktop Manager, you receive the following error message:
The remote server returned an error. (407) Proxy Authentication Required
Solution 1
To configure your proxy, go to File – Settings – Application – Proxy – Proxy settings, then choose whether Remote Desktop Manager should use the system proxy or a manually configured proxy.
Solution 2
Add devolutions.net in your proxy's exception list.
Last updated
Was this helpful?
