> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/permission-issues.md).
# Permission issues
Remote Desktop Manager permissions not being enforced are fixed by checking user types, user group assignments, and folder permission inheritance settings.
Despite having configured your permissions (whether set through inheritance or with custom permissions) you may find they are not properly enforced.
### Solution 1
When creating users, make sure that their user type are set to ***User***.
User types of existing users can be consulted at any time in ***Administration*** – ***Users*** , under the ***User Type*** column.
### Solutions 2
Often, users are created and not given permissions directly, but are instead added to user groups that have those permissions. To check if this is the case, go to ***Administration*** – ***Users***, and consult the ***User Groups*** column. You can then [reassign users to different user groups or remove them](https://docs.devolutions.net/rdm/user-group-based-access-control.md) as needed.
### Solution 3
If permissions are enforced for everything but a subset of entries, it may be that those entries inherit their permissions from a parent folder which does not inherit its own permissions from the vault settings.
To remedy this, right-click on the parent folder, go to ***Properties*** – ***Security*** – ***Permissions*** and make sure the permission is set to ***Inherited***.
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/permission-issues.md?ask=<question>&goal=<user_goal>
