> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/otp-issues.md).
# OTP issues
OTP authentication failures in Remote Desktop Manager are fixed by verifying the Key, Time step, Code size, and Hash algorithm match the source system.
If OTP is failing, check the ***Key***, ***Time step***, ***Code size***, and ***Hash algorithm*** first. These settings must match the source system exactly.
A mismatched time step is one of the most common causes of OTP failure. Verify that the client device's clock is correctly synchronized before checking other settings.
#### Common fixes
* Re-enter the OTP ***Key*** or load it from the QR image.
* Confirm the ***Time step*** matches the provider in ***Properties – Advanced*** of the OTP entry.
* Verify the ***Code size*** and ***Hash algorithm*** in ***Properties – Advanced*** of the OTP entry.
* If you use an entry, make sure its ***Source***, located in ***Properties – One-time password***, is set correctly:
  * ***Linked*** for the preferred shared OTP entry.
  * ***Inherited*** only if every parent folder also uses ***Inherited***.
  * ***None*** means no OTP is attached.
#### See also
* [How to use OTP entry in Remote Desktop Manager](https://academy.devolutions.net/student/page/2584596-how-to-use-otp-entry-in-remote-desktop-manager?curriculum_activity_id=3969784\&path_id=2628397\&sid=10036cd3-e1cb-4cbc-a5bd-f3f891627512\&sid_i=0)
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/otp-issues.md?ask=<question>&goal=<user_goal>
