> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/openvpn-loses-connection-at-launch.md).
# OpenVPN loses connection at launch
OpenVPN losing its connection when another VPN launches in Remote Desktop Manager is fixed by matching config file paths and allowing multiple connections.
{% hint style="warning" %}
Note that for OpenVPN to work properly, you will at least need version 11.15.0.0 of the OpenVPN GUI.
OpenVPN keeps losing the VPN connection when another VPN opens in Remote Desktop Manager.
### Solution
For this to work, the configuration file path must be the same in Remote Desktop Manager and OpenVPN GUI.
Also the ***Allow multiple connections*** option must be enabled in ***File – Settings – Types – VPN***.
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/openvpn-loses-connection-at-launch.md?ask=<question>&goal=<user_goal>
