OpenVPN enters wrong credentials
Last updated
Was this helpful?
Note that for OpenVPN to work properly, you will at least need version 11.15.0.0 of the OpenVPN GUI.
Starting OpenVPN in Remote Desktop Manager causes that credentials are partially entered.
Enable the feature Use authentication file in the OpenVpn entry.
Open OpenVPN's Properties.
On the Advanced tab enable Use authentication file.
Last updated
Was this helpful?
Was this helpful?
