Offline mode troubleshooting
Problem 1
Missing entries or deleted entries still showing.
Solution
Your offline cache may be out of sync with the content of the workspace. Press Ctrl+F5 to refresh the local cache.
Problem 2
System.data.sqlite.sqliteexception (0x80004005): file is encrypted or is not a database.
Solution
The offline file (offline.db) needs to be deleted manually.
Click on File – My workspace information.
Hover over the file size. It will give you the full file path, something like: %LocalAppData%\Devolutions\RemoteDesktopManager\GUID-DatasourceID\offline.db.
Close Remote Desktop Manager.
Delete the offline.db file.
Restart Remote Desktop Manager.
This will force the application to recreate the offline file.
Database disk image is malformed, trying to delete the file: /USERS/XXX/LIBRARY/APPLICATION SUPPORT/COM.DEVOLUTIONS.REMOTEDESKTOPMANAGER/GUID-DATASOURCEID/OFFLINE.DB
Click on File – Workspaces and then on Edit for your current workspace. At the bottom left, you will retrieve the Workspace ID.
Close Remote Desktop Manager macOS.
Open the Library folder by clicking on the Go menu, press and hold the Option key on your keyboard and select Library.
Follow the path Application Support/com.devolutions.remotedesktopmanager/GUID-DatasourceID and delete the offline.db file.
Restart Remote Desktop Manager macOS.
Last updated
Was this helpful?
