Network devices
It is possible to manage different devices via a web interface. However, you may have some issues to connect to the web interface in the Embedded (tabbed) display mode.
For example, you may encounter issues with the following devices:
Nagios
Cisco
Dell SonicWall
Solution
We use third-party libraries for the integration of Firefox and Google Chrome in the Embedded (tabbed) display mode.
If none of the web browsers work in Embedded (tabbed) display mode, you would need to launch the website using the External display mode and use our Devolutions Password Manager browser extension to handle the credentials.
PreviousMouse cursor invisible in Remote Desktop Manager
NextNon-admin users are unable to view passwords
Last updated
Was this helpful?
