Missing sessions from the navigation pane
Some or all entries are missing from the navigation pane. It is empty.
Solution 1
Click on Window - Reset Layout This action might take the application a minute to refresh and apply the reset.
Solution 2
The Name column is missing. Click on Window – Reset layout to bring back the Name column.
Solution 3
Refresh the local cache. Please consult Caching for more information.
Last updated
Was this helpful?
