> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/missing-navigation-pane.md).
# Missing navigation pane
Several panes are missing in Remote Desktop Manager and you seem unable to bring them back.
### Solution for Remote Desktop Manager Team Edition
1. Close Remote Desktop Manager.
2. In the ***File Explorer***, navigate to **%localappdata%\Devolutions**.
3. Copy the **RemoteDesktopManager** folder on your desktop.
4. Delete the **RemoteDesktopManager** folder in **%localappdata%\Devolutions**.
5. Restart Remote Desktop Manager.
This will create a new **RemoteDesktopManager** folder in **%localappdata%\Devolutions**. When everything is back to normal:
2. Copy the files below from the **RemoteDesktopManager** folder on your desktop into **%localappdata%\Devolutions\RemoteDesktopManager**:
**RemoteDesktopManager.cfg** **RemoteDesktopManager.enc** **RemoteDesktopManager.stv** **RemoteDesktopManager.ext** **Connections.db**
This action will restore your configuration and your local workspace.
### Solution for Remote Desktop Manager Free Edition
3. Copy the **RemoteDesktopManagerFree** folder on your desktop.
4. Delete the **RemoteDesktopManagerFree** folder in **%localappdata%\Devolutions**.
This will create a new **RemoteDesktopManagerFree** folder in **%localappdata%\Devolutions**. When everything is back to normal:
2. Copy the files below from the **RemoteDesktopManagerFree** folder on your desktop into **%localappdata%\Devolutions\RemoteDesktopManagerFree**:
**RemoteDesktopManagerFree.cfg** **RemoteDesktopManager.enc** **RemoteDesktopManager.stv** **RemoteDesktopManagerFree.ext** **Connections.db**
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/missing-navigation-pane.md?ask=<question>&goal=<endgoal>
