> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/missing-navigation-pane.md).
# Missing navigation pane
Missing panes in Remote Desktop Manager Team or Free Edition are restored by recreating the local configuration folder and reapplying saved configuration files.
Several panes are missing in Remote Desktop Manager and you seem unable to bring them back.
### Solution for Remote Desktop Manager Team Edition
1. Close Remote Desktop Manager.
2. In the ***File Explorer***, navigate to **%localappdata%\Devolutions**.
3. Copy the **RemoteDesktopManager** folder on your desktop.
4. Delete the **RemoteDesktopManager** folder in **%localappdata%\Devolutions**.
5. Restart Remote Desktop Manager.
This will create a new **RemoteDesktopManager** folder in **%localappdata%\Devolutions**. When everything is back to normal:
2. Copy the files below from the **RemoteDesktopManager** folder on your desktop into **%localappdata%\Devolutions\RemoteDesktopManager**:
**RemoteDesktopManager.cfg** **RemoteDesktopManager.enc** **RemoteDesktopManager.stv** **RemoteDesktopManager.ext** **Connections.db**
This action will restore your configuration and your local workspace.
### Solution for Remote Desktop Manager Free Edition
3. Copy the **RemoteDesktopManagerFree** folder on your desktop.
4. Delete the **RemoteDesktopManagerFree** folder in **%localappdata%\Devolutions**.
This will create a new **RemoteDesktopManagerFree** folder in **%localappdata%\Devolutions**. When everything is back to normal:
2. Copy the files below from the **RemoteDesktopManagerFree** folder on your desktop into **%localappdata%\Devolutions\RemoteDesktopManagerFree**:
**RemoteDesktopManagerFree.cfg** **RemoteDesktopManager.enc** **RemoteDesktopManager.stv** **RemoteDesktopManagerFree.ext** **Connections.db**
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/missing-navigation-pane.md?ask=<question>&goal=<user_goal>
