> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/microsoft-rdp-logoff-issues.md).
# Microsoft RDP logoff issues
Microsoft RDP logoff sending the wrong shutdown command in Remote Desktop Manager is fixed by enabling the Disable run dialog check option.
After creating and connecting to an RDP session, if you click the "LogOff" button in the Remote Desktop Manager ribbon, it appears to be sending the wrong command to the RDP session. It is sending "ashutdown /l" instead of "shutdown /l". This happens in both the Free and Team Editions.
### Solution
Check the ***Disable run dialog check*** option in ***File – Settings – Types – Remote Desktop***.
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/microsoft-rdp-logoff-issues.md?ask=<question>&goal=<user_goal>
