> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/mfa-yubikey-does-not-work-when-using-1password-entry.md).
# MFA Yubikey does not work when using 1Password entry
MFA Yubikey prompt failing on a 1Password entry with a non-global domain is fixed by matching its region to the global .com domain.
If you have a 1Password account on a non-global domain (.ca, .eu), the Yubikey prompt will fail if it mentions a login to the global domain (.com) on a [1Password credentials entry](https://docs.devolutions.net/rdm/integrations/password-management/1password.md).
### Solution
1. Open Remote Desktop Manager
2. Create or select the 1Password entry and go to the properties.
3. Make sure that the selected region for the non-global domain of the 1Password account is the same as the global domain and that all the basic information is added to the configuration.
4. Click ***Add*** or ***Update*** to save the entry.
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/mfa-yubikey-does-not-work-when-using-1password-entry.md?ask=<question>&goal=<user_goal>
