KeePass troubleshooting
Problem 1
You are prompted twice to open KeePass when connecting to a session.
Solution
In KeePass, click on Tools - Options, go to the Advanced tab and uncheck Remember and Automatically open last used database on startup.
Problem 2
The following plugin is incompatible with the current KeePass version.
Solution
Make sure that the installation of KeePass was successful.
Delete all the RemoteDesktopManager.Connector.dll and RemoteDesktopManagerPlugin.dll files that you may have in the installation folder of KeePass.
Problem 3
KeePass Direct mode fails.
Solution
For this to work, you will need to have your Key Derivation function set to one of the following options depending on your Encryption You can locate this in your KeePass Database settings under the Security section.
Encryption CHACHA20
Argon2d
AES-KDF
Encryption AES/Rijndael
Argon2d
See also
Last updated
Was this helpful?
