Integrated security issues with SQL Server
Since issues can arise from multiple sources, when setting up integrated security on an SQL server workspace, we detailed a couple of steps to help out and diagnose the source.
Steps
Retrieve log details
In Remote Desktop Manager go to Help – Application Logs – Report (tab).
Click Delete All.
In File – Settings – Advanced:
Raise the Debug level to 1.
Uncheck Disable stack trace.
Click OK.
Reproduce the issue.
Once the issue is reproduced, go to Help – Application Logs – Report (tab).
Click Send to Support.
If you already have an ongoing ticket with us, please specify the ticket number in the Subject.
Validate if the database is contained
Run the following script to find out if your database is contained. Make sure to replace rdm-database-name with your Remote Desktop Manager database name.
SELECT name, containment, containment_desc, compatibility_level FROM sys.databases WHERE name = 'rdm-database-name';
Validate if the SQL server is joined to the domain
If you execute the statements manually in SSMS (SQL Server Management Studio) what do you get?
Last updated
Was this helpful?
