High CPU usage
With an SQL workspace, if you experience high CPU usage on your systems, especially in Terminal Services / Remote Desktop Services (RDS) environment, it may be caused by the entry state verification feature.
Solution
Disable the option Allow entry states (locked, running, checked out) in Administration – System settings – Vault to improve performance on your servers and your workstations.
Last updated
Was this helpful?
