Skip to content
Error code fail (-1) non specific error
When opening a SSH connection in Remote Desktop Manager, the following error message can appear: An unexpected error has occurred: Error code FAIL (-1) non specific error.
Solution
In the Advanced tab of your session, set the Algorithm support option to Custom and check the missing one(s) in the list.
It is also possible to globally reactivate all the algorithms in Remote Desktop Manager via the File – Settings – Entry types – Sessions –Terminal – Algorithm support menu.
If you are still unable to connect after enabling the algorithm, go into the entry Properties – Advanced tab and check the Skip environment variable setup.
Last updated
Was this helpful?
