> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/embedded-credentials-not-working-in-chromium-based-browsers.md).
# Embedded credentials not working in Chromium-based browsers
Fix embedded credentials no longer working in Chromium-based browsers by configuring a typing macro to auto-fill usernames and passwords.
Google Chrome, and therefore every Chromium-based web browser, no longer support embedded credentials in URLs. As a result, credentials cannot be pushed directly into a basic authentication prompt anymore.
### Solution
In Remote Desktop Manager, a typing macro can be set up to automatically input usernames and passwords:
1. Select the entry to edit, then go to ***Properties*** – ***Connection*** – ***Events***.
2. In the ***After Open*** tab, set the initial wait time to 2 or 3 seconds, and enter in the typing macro box: `$USERNAME${TAB}$PASSWORD${ENTER}`
3. Go to ***Properties*** – ***Security*** – ***Security Settings***, and make sure the ***Allow Password in Variable*** checkbox is checked.
Using this method, usernames and passwords should be automatically typed on session launch.
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/embedded-credentials-not-working-in-chromium-based-browsers.md?ask=<question>&goal=<user_goal>
