Skip to content
Display issue in the dashboard
Column width are getting wider in your dashboard.
Solution
  1. Close Remote Desktop Manager.
  2. Open a file explorer to locate your installation folder, usually in %localappdata%\Devolutions\RemoteDesktopManager or %localappdata%\Devolutions\RemoteDesktopManagerFree.
  3. Locate the file name RemoteDesktopManager.ext.
  4. Rename it RemoteDesktopManager.old.
  5. Restart Remote Desktop Manager.
Last updated
Was this helpful?
