Disable UDP usage in Remote Desktop Manager
Disabling UDP usage can sometimes resolve issues, notably those related to Remote Desktop Manager hanging during the log-off process of an RDP session. You can disable it via Remote Desktop Manager or via the registry.
Disable UDP usage via Remote Desktop Manager
On all sessions
Run Remote Desktop Manager as an administrator.
In the ribbon, go to Tools – More tools.
Select the Local RDP/RemoteApp Manager from the tools list.
Disable UDP settings.
On a per-session basis
In Remote Desktop Manager, first ensure RDP API hooking is enabled in File – Settings – Types – Sessions – Remote Desktop (RDP) – Enable API hooking. Save your changes if applicable.
Select your RDP entry and go to its properties.
In the General section, go to the Advanced tab and set Disable UDP transport to Yes.
Click Update to save your changes.
Disable UDP usage via the registry on the client workstation
In the Registry Editor, navigate to
HKLM\SOFTWARE\Policies\Microsoft\Windows NT\Terminal Services\Client.Create a DWORD named
fClientDisableUDPand assign it a value of1.
See also
Last updated
Was this helpful?
