> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/devolutions-gateway-id-default-not-found-error.md).
# Devolutions Gateway ID default not found error
Fix the Devolutions Gateway ID default could not be found error by setting a default gateway in Devolutions Server or Devolutions Cloud.
In Remote Desktop Manager, if session recording is configured for a gateway but a default gateway has not been set, then the session cannot go through. Remote Desktop Manager then returns the following error: "Unable to connect with Devolutions Gateway: Gateway ID (default) could not be found."
### Solution
To remedy this, open your Devolutions Server or Devolutions Cloud workspace, go to ***Administration***, and click on the Devolutions Gateway icon.
Set the desired default gateway in the ***General*** section of the Devolutions Gateway menu and save your changes.
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/devolutions-gateway-id-default-not-found-error.md?ask=<question>&goal=<user_goal>
