Data recovery
In the event of data loss due to hardware failure, it is still possible to recover data from your storage device if it is still useable.
Solution
On the storage device that failed, navigate to C:\Users%USERNAME%\AppData\Local\Devolutions and copy the entire RemoteDesktopManager or RemoteDesktopManagerFree folder.
This folder will contain the local workspace (SQLite or XML) as well as your configuration file.
Paste this folder at the same place on your new computer and you should retrieve your data.
Last updated
Was this helpful?
