CyberArk workspace issues
Here is the list of all known CyberArk workspace issues.
No license found
Solution
To perform the initial configuration steps, make sure you first connect to a user who has the required CyberArk permissions.
Unable to edit an account
Solution
The CyberArk workspace will recognize Add Safe as the Admin. This also controls the add/edit/delete actions in the user interface. Regardless of Add Safe, CyberArk will validate the correct user permissions when an action is requested (add/edit/delete) and will prevent you from performing tasks that the current user is not authorized to perform.
PreviousCyberArk prompts for reason to connect after Remote Desktop Manager update
NextDark release notes when dark theme is active
Last updated
Was this helpful?
