Connections are missing
User's connection list is missing. This either mean that the Name column is missing or the navigation pane as a whole is missing.
The navigation pane is visible but the connection list is missing
Right-click where the Column name is supposed to be displayed and click on Column Chooser. From there, scroll down the list and double click on "Name".
The whole navigation pane is missing
Go to the Window tab and use Reset Layout.
PreviousConnection issues with SQL workspaces
NextCyberArk prompts for reason to connect after Remote Desktop Manager update
Last updated
Was this helpful?
