> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/cisco-anyconnect-connection-issues.md).
# Cisco AnyConnect connection issues
Fix common Cisco AnyConnect connection issues in Remote Desktop Manager, including missing add-ons, VPN startup, and password delivery failures.
This article contains some of most common errors that can come up when Cisco AnyConnect is having issues at connection.
### The Cisco AnyConnect entry is missing from the new entry window
Make sure that the Add-on is enabled by going under ***Tools*** – ***Extension manager*** – ***VPN/Tunnel/Gateway***, select ***Cisco AnyConnect VPN Client*** and click ***Activate add-on***.
### The VPN does not start
1. Make sure that the installation path of the Cisco AnyConnect VPN Client is valid by going under ***File*** – ***Settings*** – ***Application*** – ***Paths*** – ***Configure installation path*** – ***Applications*** – ***VPN***, select ***Cisco AnyConnect VPN Client*** and use the ellipsis button to choose the correct installation path.
   <div data-gb-custom-block data-tag="hint" data-style="info" class="hint hint-info"><p>This step only applies if you are not using the default installation path <em><strong>C:\Program Files (x86)\Cisco\Cisco Anyconnect VPN Client</strong></em>.</p></div>
2. Run Remote Desktop Manager with elevated permissions (run as administrator).
### The first connection attempt fails during a Cisco Secure Client upgrade
Cisco Secure Client can upgrade itself when it connects, which interrupts the first connection attempt. Remote Desktop Manager for Windows detects the upgrade when the Cisco downloader (`vpndownloader`) is running after the Cisco client closes, and handles it automatically:
1. The "Waiting for the Cisco Secure Client upgrade to complete. The VPN connection will be retried automatically." message appears while the upgrade runs.
2. When the upgrade is complete, Remote Desktop Manager waits 5 more seconds, then opens the VPN connection again. It retries only once.
If the entry uses an SMS passcode as its second password, enter a new passcode when Remote Desktop Manager prompts for it again.
Remote Desktop Manager waits up to 5 minutes for the upgrade. Click ***Cancel*** in the waiting message to stop the connection. If the wait times out or the second attempt fails, open the entry again once the upgrade is complete.
### Password is not sent when trying to establish a connection
1. Make sure that the latest version of CiscoAnyConnect is installed.
2. Go in the ***General*** properties of the Cisco AnyConnect VPN Client entry, under the ***Connection*** – ***General*** tabs, and change the ***Wait prior credential*** value to match the time it takes to fully load the VPN on the local machine.
3. Try to turn on and off the UAC in Windows.
4. Test the Cisco Command Line (CLI) outside Remote Desktop Manager to see if the same issue occurs.
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/cisco-anyconnect-connection-issues.md?ask=<question>&goal=<user_goal>
