> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/cisco-anyconnect.md).
# Cisco AnyConnect
Fix Cisco AnyConnect sending an incomplete password or group number by toggling Windows UAC settings in Remote Desktop Manager.
The Cisco AnyConnect add-on does not send the proper information like the password or the group number to the **vpncli.exe** DOS window to establish the VPN connection.
For example, only the half of the password is sent to the Cisco AnyConnect window.
### Solution
The Cisco AnyConnect add-on use sendkeys to send information to the **vpncli.exe** window. The issue that we encounter is caused by the Windows UAC feature. Enabling/Disabling UAC on your computer should resolve the issue.
1. On your computer, go in ***Control Panel – User Account – User Account Control Settings***.
2. Select ***Never Notify*** to turn off the option.
3. Select ***Notify me*** or ***Always notify*** to turn the option on.
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/cisco-anyconnect.md?ask=<question>&goal=<user_goal>
