> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/beyondtrust-issues.md).
# BeyondTrust issues
Fix common BeyondTrust Password Safe Dashboard errors, including URI format, 404, 500, and 401 issues, by correcting the host and API key fields.
### Problem 1
System.uriformatexception: invalid uri: the format of the uri could not be determined.
#### Solution
In the ***Host*** field of the BeyondTrust Password Safe Dashboard entry, make sure to enter the server name like <https://beyondtserver>.
Do not enter the IP address of the server. Entering the IP address instead of the server name will return this error.
### Problem 2
System.net.webexception: the remote server returned an error: (404)
#### Solution
Do not enter the web URL to access the console from a web browser, example <https://beyondtserver/eEye.RetinaCS.Server/PasswordSafe>.
### Problem 3
Not found system.net.webexception: the remote server returned an error: (500) internal server error.
#### Solution
### Problem 4
System.net.webexception: the remote server returned an error: (401) unauthorized.
#### Solution
In the ***Application API*** key field of the BeyondTrust Password Safe Dashboard entry, make sure that you have entered the appropriate key.
### Problem 5
Beyond Trust Password Safe or BeyondTrust Password Safe Dashboard is empty and no error is returned.
#### Solution
Make sure that the ***Enable for API*** access option is checked for your privileged account in BeyondTrust.
Make sure that the account has the ***Password Safe System Management*** permission for the BeyondTrust REST API. This permission is required to read, write, modify, or trigger updates and refreshes on managed systems through the public REST API. When it is missing, BeyondTrust can return the following error silently, so the Password Safe or dashboard stays empty and no error is shown:
System.Net.WebException: The remote server returned an error: (403) Forbidden.
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/beyondtrust-issues.md?ask=<question>&goal=<user_goal>
