> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/azure-sql-connection-issues.md).
# Azure SQL connection issues
Troubleshoot Azure SQL login and connection failures in Remote Desktop Manager with a step-by-step username, workspace, and credential checklist.
Here is a validation list to help resolve issues when failing to login and connect with Azure SQL in Remote Desktop Manager.
* Was the user added/created in Remote Desktop Manager?
* Is the spelling of the username in Azure and Remote Desktop Manager the same?
* Is the spelling of the database name in Azure and Remote Desktop Manager the same?
* Compare the workspace configuration with one that works from another user in ***File – Workspaces***.
  * If it still fails, [Export and Import the workspace configuration (.rdd)](https://docs.devolutions.net/rdm/getting-started/workspaces/import-and-export-a-workspace.md) from the working user.
  * Ask the user from whom it works to launch a connection with their credentials. Doing so will confirm a connection can be made to the Azure database from this instance of Remote Desktop Manager.
    * If it does work, change the credentials in Remote Desktop Manager with the ones of the initial failing user and retest with these credentials.
    * If it does not, install SSMS and try to connect with the same failing user and authentication method to validate a connection can be made to the Azure database.
* If all fails, contact our [customer support team](mailto:service@devolutions.net).
GET https://docs.devolutions.net/rdm/knowledge-base/troubleshooting-articles/azure-sql-connection-issues.md?ask=<question>&goal=<user_goal>
