AdalException error
PreviousActive Directory synchronizer permissions
NextAdding a new entry in the user vault on SQL Azure does not work
Last updated
Was this helpful?
When using Integrated Security as an authentication method, Remote Desktop Manager returns an error beginning with the following text:
AggregateException - One or more errors occurred following with an AdalException error.
You need to install a library from the Microsoft download center.
Please note that you will need to install both the x64 and x86 bits package.
Last updated
Was this helpful?
Was this helpful?
