> For the complete documentation index, see [llms.txt](https://docs.devolutions.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/workspace-best-practices.md).
# Workspace best practices
Apply Remote Desktop Manager workspace best practices, including vault structure, inheritance, and credential linking, to simplify long term maintenance.
Configuring a database can lead to issues such as centralizing everything in a single [vault](https://docs.devolutions.net/rdm/concepts/basic-concepts/vaults.md) or using too many [user-specific settings](https://docs.devolutions.net/rdm/ribbon-menu-bar/edit/specific-settings.md). Here is how you can avoid these issues and create a structure that is easier to maintain.
### Optimize workspace structure
Separate the [workspace](https://docs.devolutions.net/rdm/concepts/basic-concepts/workspaces.md) into [vaults](https://docs.devolutions.net/rdm/concepts/basic-concepts/vaults.md). It is recommended that vault entries be organized into [folders](https://docs.devolutions.net/rdm/concepts/basic-concepts/folders.md) to allow for [inheritance](https://docs.devolutions.net/rdm/concepts/intermediate-concepts/inheritance.md).
### Inheritance
[Inheritance](https://docs.devolutions.net/rdm/concepts/intermediate-concepts/inheritance.md) means that certain properties or attributes of a higher-level entry are automatically passed down to lower-level entries that ***inherit*** from it. This reduces the need for repeated entry-specific settings.
### Credential linking
Create a credential entry to associate with a remote connection, allowing the connection to be made without having to view or access the credentials. Credentials no longer need to be updated in multiple entries; remote connections automatically retrieve them from the linked credential entry.
1. Create a new ***credential entry*** ( for example, a ***Username and Password*** entry) and enter the information.
2. Open a ***remote connection entry*** such as an RDP entry.
3. Go to the ***properties.***
4. Open the ***Credentials drop-down menu*** and click ***Linked*** (vault).
5. Select the credential entry from the ***credentials drop-down menu***.
6. Click ***Update*** to save and close the window.
7. Open the entry.
8. The remote connection will then automatically use the credentials from the linked entry.
GET https://docs.devolutions.net/rdm/knowledge-base/knowledge-base-articles/workspace-best-practices.md?ask=<question>&goal=<user_goal>
