Wake-on-LAN (WOL)
Wake-on-LAN (WOL) is an Ethernet computer networking standard that enables a computer to be powered on or awakened remotely via a network message. This is an OS-agnostic (independent from the operating system) feature that operates by broadcasting a specially crafted “magic packet” at the data link layer. When in a low-power state, the target computer keeps its network card active. Upon receiving the magic packet, the network card triggers the computer to wake up, powering it on and initiating the boot process.
To use this feature, ensure that the target computer's motherboard supports WOL and that it is enabled in the BIOS settings. Additionally, the computer must be within the local area network (LAN) and not connected via a VPN.
WOL operates below the IP level, meaning the sending and receiving devices must be on the same local area network (LAN). This limitation prevents WOL packets from being sent over remote IP-based connections like SSH or VPN.
Remote Desktop Manager sends the magic packet over UDP, on port 7 by default. A different port can be configured if needed. To wake a machine on a different subnet, the router must be set to forward UDP packets on the designated port. Within the same subnet, no router configuration is needed.
Enabling Wake-on-LAN
The first step is to verify that the computer supports Wake-on-LAN. Here are the key requirements to check:
  • Network card: Confirm that the network card supports Wake-on-LAN. Most modern network cards include this feature.
  • Power supply: Ensure the computer’s power supply can provide power to the network card while the system is in a low-power state.
  • BIOS settings: Enable Wake-on-LAN in the computer’s BIOS settings.
  • Router configuration: Verify that the router is configured to forward broadcast packets, especially if waking a computer on a different subnet.
  • Operating system: Configure the operating system to enable Wake-on-LAN. This typically involves settings in the device manager or network adapter properties.
Configure Remote Desktop Manager
To enable Wake-on-LAN for a session, provide a valid MAC (Media Access Control) address in the session's properties. Follow these steps:
  1. In the session entry's properties, navigate to View – Asset.
  2. Locate the Mac field in the Network section.
  3. Click the Discover button within the Mac field to attempt automatic detection of the MAC address. If the discovery is unsuccessful, manually enter the MAC address.
  4. Save changes.
The fields of the Network section are described in Asset.
About MAC address discovery
The discovery process for retrieving the MAC address begins with an attempt to use the ARP protocol. This method is fast and does not require authentication, but it relies on specific network conditions, such as the devices being on the same subnet. If these conditions are not met, the ARP attempt will fail. On Windows, the process then switches to using WMI (Windows Management Instrumentation), which is slower. Remote Desktop Manager uses the credentials specified in the session entry properties or those provided in the Tools section, then tries again without credentials. On macOS and Linux, only ARP is used.
Wake on LAN broadcast IP address
The Wake on LAN broadcast IP address setting determines where the magic packet is sent. If specified, Wake-on-LAN sends the packet to the network associated with that IP address. If not, the global Wake on LAN broadcast IP address of the application settings is used, then 255.255.255.255. The Port field overrides the default port used to send the magic packet. By default, the packet is sent on port 7.
In the entry properties, go to Management tools – Wake on LAN. These settings are described in Wake on LAN.
Use Wake-on-LAN
Once all settings are correctly configured, Wake-on-LAN can be triggered in Tools and automation – Wake on LAN from the session entry's contextual menu.
Last updated
Was this helpful?
