Use multiple versions of a third-party application
If you have multiple different versions of an application installed on your workstation and wish to use both versions within Remote Desktop Manager, you can configure this as follows:
When you configure your Application Installation Path In File – Settings – Application – Paths, when configuring the Application installation path, separate each path with a semicolon (;). Remote Desktop Manager will then prompt you with a selection list, allowing you to choose the desired version when launching the application.
Example: To specify two paths, such as C:\Program Files\Appsv1 and D:\Program Files\Appsv2, enter them as follows:
C:\Program Files\Appsv1;D:\Program Files\Appsv2
PreviousUnsafe Google Chrome integration in Remote Desktop Manager Windows
NextVersion schema compatibility for Remote Desktop Manager and Devolutions Server
Last updated
Was this helpful?
