System information report WMI commands
Here are the WMI commands used by the System Information Report entry in Remote Desktop Manager.
Logical drives
Perform the WMI query "Select * from Win32_LogicalDisk" and then filter on the result.
Network adapters
Perform the WMI query "Select * from Win32_NetworkAdapterConfiguration" and then filter on the result.
Products
Look in the following registry keys for the installed software through WMI using the StdRegProv class.
In HKEY_LOCAL_MACHINE:
Software\Microsoft\Windows\CurrentVersion\Uninstall
Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall
Software\Classes\Installer\Products
In HKEY_CURRENT_USER:
<USER SID>\Software\Microsoft\Windows\CurrentVersion
<USER SID>\Software\Microsoft\Installer\Products
All of the necessary information for the list of products is contained within these registry keys.
System
The system setting contains multiple different calls over WMI.
Bios information: Fetch the information in the Win32_Bios class.
TPM information: Fetch the information in the Win32_Tpm class.
CDRom information: Perform the query "SELECT * FROM Win32_CDROMDrive" and then filter on the result.
Computer system information: Fetch the Win32_ComputerSystem class
Memory information: Perform the query "SELECT * FROM Win32_PhysicalMemory" and then filter on the result.
Monitor information: Perform the query "SELECT * FROM Win32_DesktopMonitor" and then filter on the result.
Motherboard information: Perform the query "SELECT * FROM Win32_BaseBoard" and then filter on the result.
Processor information: Perform the query "SELECT * FROM Win32_Processor" and then filter on the result.
Sound device information: Perform the query "SELECT * FROM Win32_SoundDevice" and then filter on the result.
Video controller information: Perform the query "SELECT * FROM Win32_VideoController" and then filter on the result.
Other device information: Perform the following queries and filter the results:
"SELECT * FROM Win32_Keyboard"
"SELECT * FROM Win32_PointingDevice"
Operating system information:
For the main OS version, fetch the Win32_OperatingSystem class.
For the build version, use the StdRegProv class to access the registry key SOFTWARE\Microsoft\Windows NT\CurrentVersion to check the version.
Antivirus: We switch to the WMI context SecurityCenter2, then fetch the information from the AntivirusProduct class.
Local accounts
Perform the query "SELECT * FROM Win32_Account" and then filter on the result.
Printers
Perform the query "SELECT * FROM Win32_Printer" and then filter on the result.
Services
Perform the query "SELECT * FROM Win32_Service" and then filter on the results.
Shares
Perform the query "SELECT * FROM Win32_Share" and then filter on the result.
Startup
Perform the query "SELECT * FROM Win32_StartupCommand where User != '.DEFAULT' and User != 'NT AUTHORITY\SYSTEM'" and then filter on the results.
Windows hotfixes
Perform the query "SELECT * FROM Win32_QuickFixEngineering" and then filter on the result.
Last updated
Was this helpful?
